Assault King
- 0
- 1
- Louisville, Kentucky
Evening folks,
I will try to provide more detail or pictures if needed, I've never really tinkered with cars before but loved the humvee in the military.
I recently picked up my first humvee Monday. Fired right up. It's a M1097R1 with a 3 speed, and 6.5. It has what I believe is a 200 amp alternator with a dual voltage regulator atop labeled 14v / 28v. Upon sitting in the garage overnight with two good batteries, it drained both batteries to zero. I cleaned all of the connections, did a slow recharge on both batteries til full and put them back in. With the truck off, I can not hear any solenoids engage when the negative terminal is connected.
With the truck running, the trucks voltage gauge bottoms out in the overcharge. When I put a multimeter on the voltage regulator:
IGN to ground : 34 volts
AC to ground : 28 volts
Alternator positive cable to ground: 34 volts
14 volt to ground : 0 volts
Now I'm not sure if the batteries will drain again as I'm gonna give it a few hours and check again. I'm not sure what I have that's bad or if I have a parasitic draw. I'm a machinist, but electricity has always been rough for me. Cheers.
