M1097R1 Running Cold?
Assault King
Louisville, Kentucky
Morning folks,
I have a M1097R1 with the NA 6.5 and 3 speed trans. During the summer the truck's temperatures were textbook. Winter has rolled around and I think I might have a problem. In my routine, I wake up, start it, it might idle for 5-8 minutes then I drive off. My work is 10 miles away and it barely hits 150° by the time I'm in the parking lot but the blower is shooting out warmer air.
Had a busy day yesterday and was driving all over the place, it would get up to 180 but would practically drop at idle for a bit. Fan hasn't kicked on at all, Upper radiator hose is hot, coolant topped off.. Temperature outside is around 20° F. My work has a laser thermometer and I could use it on the casting I guess if needed while driving on lunch.
Do I have a thermostat sticking, or a cold truck? Would a plastic board on the grille help? Thanks
19,887
Morning folks,
Sure... A plastic piece of an old Political Yard Sign will tell you pretty quickly if it improves your problem.
19,887
Thank you for the input, I have some board that I use for custom chip/splash guards at work to ziptie on there. My only worry is, will the transmission cooler still get enough airflow to chill? I'm not familiar with the 3l80
Pretty sure that won't be a problem. The transmission cooler is way over-engineered.
