m109a3 start failure
grouper
Cedar Bluff, Alabama
went to crank the m109a3 this morning and heard a popping sound. I checked the battery box and discovered a burned cable connecting the two batteries, I think its called a dog bone cable. I'm not good with electrical problems. Any ideas as to why the burned cable end would be greatly appreciated.
jdr2710
Colorado Springs, CO
It might be as simple as a loose connection on the battery terminals. With the amazing amount of current flowing during cranking it doesn't take much resistance to cause problems. I had a system that did exactly that a few years ago, just a little amount of resistance on the terminal and as I drew 400amps through it, it produced enough heat to melt the terminal off of the battery. All I was left with was a puddle of lead where the post used to be.
Good Luck,
Jeff
