Hi there, I‘m hoping someone may be able to answer a few questions about the M10A rough terrain forklift. A small equipment seller close by has two of the M10‘s. Both are 1983 models and are pretty much identical. One has 2500 hours, the other has 1500 hours. My biggest question is how much will these actually lift? I know it’s rated for 10k, but a 37k pound machine should lift a lot more than that. If the M10‘s are the Dresser 530, it should lift about 21k pounds. If they are Dresser 540’s, they should lift around 27k pounds. I need a machine to lift about 20k pounds, I’m moving large landscape rocks/boulders. Other questions are: Are these good machines? Any problems to look for? The machine with 2500 hours has coolant around number 1 injector that has run down to the oil pan, is this a possible cracked head or just some type of seal around the injector leaking? I’m not very familiar with the 466 engines.
Thanks for any help
Thanks for any help
