M1101 and a M923
bigwhale
alaska
Can I tow a M1101 behind a dually m923? I dont have the super singles on the truck. Will the height be there on the trailer to match the pintle on the truck or will it be tilted ? Do the electric plugs match up? Thanks.
juanprado
2,916
Metairie/La (N'awlins)
The trailer hook up is universal on all military trailers. No Problems there. all 24v. I suspect the height would have a slight tilt maybe 6-8 inch but should be ok tow. Probably real difficult to back up straight though.
sigo
Lieutenant Colonel
405
Leavenworth, KS
It's even tilted a bit when towed with a deuce. It's a pain to back up too. You also won't have much room for error when it starts to turn on you. Hard to see it back there as well.
Bring some dunnage to put under the tongue jack wheel, it doesn't crank out enough to raise it up to truck pintle level. One man can lift it easy enough to slide a block under the wheel, but it's harder for one man to lift from the side and on to the truck pintle. Much easer to slide a block under and crank it up to match pintle height.
