M1101 Electrical Cable wire colors?
Amer-team
32
Centralia/WA
The wire and pin connectors backed out of the connector and I am trying to find a diagram that shows which color wire goes in which hole. For instance, it looks like the red wire is for marker lights and is E.
There are several good threads that point to the direction of how to adapt to civilian usage but they all seem to assume a good connector on the trailer side. From these threads I have figured out the turn signals and marker lights, so it looks like the other wires pertain to blackouts?
In the threads there is a nice wiring diagram but they list wire numbers and I am looking at the same diagram in a TM.
Any help with the rest of the colors. I just need to put the pins back in the right holes. Thanks for the help with this.
As a maintenance point, if you have an 1101, make sure to check the tension on the clamp that puts pressure to keep the wires in the connector head. It is a little irritating when the wires pull out.
Amer-team
32
Centralia/WA
I will look thank you. So far I have 4 TM's sitting on my desk and have looked at numerous threads, with no referral to what the color is of the 8 wires in that coupling. There are 4 red and 4 black, with various colored stripes and I have figured out 4 of the 8 from other threads.
Amer-team
32
Centralia/WA
Thank you again for the tip. Just looked up 392-14&P. Section 4-19.2. It is essentially the same diagram that I am looking at for another trailer. Was hoping to find somewhere that it said you put red/white in B, Blk/red in J, Black in ? It can be figured out and I will be better for doing so, but they could have made it simpler for someone like me that is not electrically oriented and simple.
Tinwoodsman
76
Comfort, Texas
Amer-team, I assume you are trying to match your vehicle plug configuration to the harness on the 1101. There is a connecting block on the chassis about 1/3 of the way back under the box. If you pull each wire away you will see a small metal number plate. You can match these numbers to the wiring diagram in the TM. It will not be color pertinent but it will tell you the circuit, i.e. "stop light" You can ID the circuit on your vehicle and go from there. Good luck.
Amer-team
32
Centralia/WA
Glassk, thank you for that link. I had read that one, that is how 4 of the wires were Id'd, am still trying to figure out the other 4.
Tinwoodsman thank you also. That is where I was going to have to go if no one had an easy way. Once I get it figured out, will write it in my TM and post the results. It also looks like over the years there have been some minor differences in wire colors.
