Back to the interior.
I built a cabinet using materials I had in my woodshop (3/4" ply for the carcass, as it was going to support the top bunk).
I used surplus laminate flooring from building our house and extended the bunks out to 24" using 3/4" ply. I cut a king size 6" ultra plush memory foam mattress into three (3) pieces using a sawsall and two (2) clamped 2x4s as a guide. We have three (3)
super comfortable bunks for a total of $160 from Amazon. I decided to do the mattress retaining trim out of cherry (I build furniture as a serious hobby).
I also repurposed a heavy post support that was installed in the M1102 and a fitting from the small air vent in the side of the shelter, added a piece of PVC as a vertical member, then fitted it all together with the cherry and purple heart table top I made. It breaks down and can be stowed easily.
I installed a second RV window on the right side to make it feel bigger. All wiring complete here, with a couple multi-gang switch panels to operate exterior lights, vent fans, and control power to the two (2) dual USB charging ports. You can see the 110v outlet on the right.
![0518201203_HDR.jpg 0518201203_HDR.jpg](https://www.steelsoldiers.com/data/attachments/561/561489-949e2ceb4ce55280942e0804cc2594a7.jpg)
![0518201204.jpg 0518201204.jpg](https://www.steelsoldiers.com/data/attachments/561/561490-5a4baed224d51582bef7066808acb87d.jpg)
![0519201905_HDR.jpg 0519201905_HDR.jpg](https://www.steelsoldiers.com/data/attachments/561/561491-71910fbcce7eb3fbefb67c4207f6081d.jpg)
![0603201739_HDR.jpg 0603201739_HDR.jpg](https://www.steelsoldiers.com/data/attachments/561/561492-5906a71b511c376877695a4d2d448d25.jpg)
![0610201708_HDR.jpg 0610201708_HDR.jpg](https://www.steelsoldiers.com/data/attachments/561/561493-2b4307747b9a077da17aee1f132bb545.jpg)
![0610201708a.jpg 0610201708a.jpg](https://www.steelsoldiers.com/data/attachments/561/561494-330ee31d7a67dab663f59e352e914112.jpg)
![0610201708b.jpg 0610201708b.jpg](https://www.steelsoldiers.com/data/attachments/561/561495-f4b85f9d5871ed9de120712bd2cabcc1.jpg)
