SUPERSPORT
- 2
- 18
- Ohio
Anyone pull an M1101/02 with a M939? Any reason not to?
Anyone have pictures of how it looks?
I find backing these trailers improves one's ability. The M1102 is a very good teacher and quick to punish impatience.
The only issue I see is that when you are backing the trailer up it will turn before you know it and you can jack knife it and bend the frame in a heartbeat.
This is especially true if you have a cargo cover on the truck and cannot see the trailer except with the mirrors.
A short trailer will make a fool out of the best driver if he is not used to maneuvering one.
This is about correct. I'm not really worried about backing up. I drive semi for UPS and pull doubles. When building your set we "cowboy" the dolly. We are not supposed to. Back first trailer with dolly already hooked up. 2 pivot points and you can't see the dolly. You get a "feel" and you turn before you need to. Like he said, when you see it in the mirrors it's too late.....When you see it in the mirrors it is too late!!!!
This is what I am wondering. I think the lunette ring is 29.5" on M1102. My 5 ton is 40 miles away right now so I can't measure the pintle hook height. I think it may be about 6" or so higher. Can anyone run out and measure theirs?Backing up with an 1102 behind my deuce on rough terrain made me feel like a fool. It does indeed turn before you can see it, and it turns FAST, especially when empty. But it pulled great. I couldn't feel it and could barely see it.
Seems like it would ride really high in the front hitched to a 5 ton.
That looks great!!!! What is the height of your pintle hook on the deuce?I tow mine behind my deuce. Yes you have to be careful to back it up.View attachment 503533
33" and I'm running XZL tires so that should be the tallest configuration.This is what I am wondering. I think the lunette ring is 29.5" on M1102. My 5 ton is 40 miles away right now so I can't measure the pintle hook height. I think it may be about 6" or so higher. Can anyone run out and measure theirs?
That's not too bad a difference at all. Thank you.33" and I'm running XZL tires so that should be the tallest configuration.
I think they are exactly the same. Just different data plates. You have any pictures of it behind either set up?How much different is the 1101 compared to the 1102, I pulled a 1101 with my 819 as well as a 923/cover (1101 does lean back a bit), I had NO issues in backing down the road, into my driveway, and the 1101s home on the side of the shop.
Thanks for the picture. Doesn't look that bad at all for the height difference. Looks awesome actually.Supersport is correct, they are the same.
I've pulled one behind my M931A2's, looks a bit funny, but works.
Cheers
I measured to the bottom of the pintle as thats where the bottom of the lunette will setMy pintle hook is 35 1/2 inches to center.
