M1102 trailers at Ft Mead for MIST Surface Antenna Group (SAG)
JBT
Northern Virginia
Recently there were several M1102 trailers on GL at Ft Meade with equipment mounted on them.
Someone wondered what the equipment was.
I have not seen one up close yet, but did some research.
The trailers data plate lists the trailer as part of AN/TSQ-219(V)2.
Part number A3254715v2.
It also lists:
POWER UNIT, DIESEL ENGINE DRIVEN, HIGH MOBILITY TRAILER MOUNTED,
10 kW, 60 Hz, PU-798A (NSN 6115-01-413-3818)
in which case the equipment is the switch box. TM 9-6115-660-13&P
TACTICAL EXPLOITATION SYSTEM-FORWARD (TES-F)/
AN/TSQ-219(V)2, BOIP M101AA, LIN Z16057 IS A TACTICAL SUITE OF
EQUIPMENT FOR WHICH THE PRIMARY MISSION IS EXPLOITATION, ANALYSIS,
AND DISSEMINATION OF NEAR-REAL-TIME INTELLIGENCE INFORMATION.
1. TES-F IS COMPRISED TEN (COMPONENT) WORKSTATIONS, MTD IN
SIX NON-STANDARD (COMPONENT) SHELTERS, MTD ON SIX OF THE SEVEN
(ASIOE) M998/HIGH MOBILITY MULTIPURPOSE WHEELED VEHICLES (HMMWV)/LIN
T61494. THE SEVENTH HMMWV (EQUIPMENT TRANSPORT VEHICLE (ETV)) DOES
NOT CARRY A SHELTER. TWO OF THE SEVEN HMMWV PULL (ASIOE) 3/4 T.
TRAILERS/Z36272. THERE IS ALSO ONE ASIOE 2 1/2T. LMTV TRUCK/M1078/
LIN T60081, WHICH TOWS THE 2T. (COMPONENT) MIST (MODULATED
INTEROPERABLE SURFACE TERMINAL) SURFACE ANTENNA GROUP (SAG) TRAILER.
2. TES-F MAY BE DEPLOYED IN ONE OF 5 CONFIGURATIONS EMPLOYING
COMBINATIONS OF THE NINE FUNCTIONAL SUBSYSTEM COMPONENTS.
EMPLOYMENT CONFIGURATIONS INCLUDE:
a. BASIC:
- THE FORWARD COMMUNICATIONS VEHICLE (FCV): SHELTER-MTD HMMWV TOWING
60KW GEN. SHELTER CONTAINS 2 WORKSTATIONS, CABLING, ETC.
- THE COMMUNICATIONS SUPPORT VEHICLE (CSV): SHELTER-MTD HMMWV CON-
TAINING WORKSPACE, CABLING, ETC.
b. FULL SIGINT:
- THE FCV
- THE CSV
- THE MiDAS VEHICLE (MDV): HMMWV TOWING COMPONENT MiDAS TRAILER
c. NATIONAL IMINT:
- THE FCV
- THE CSV
- THE IMAGERY SUPPORT VEHICLE(ISV): HMMWV TOWING COMPONENT 60KW GEN
d. FULL IMINT:
- THE FCV
- THE CSV
- THE ISV
- THE IMAGERY PROCESSING VEHICLE(IPV): HMMWV TOWING ASIOE REMOTE
EQUIPMENT TRAILER
- THE MIST ELECTRONICS VEHICLE (MEV): HMMWV TOWING COMPONENT
30KW GEN
- THE MIST SURFACE ANTENNA GROUP (SAG) TRAILER: TRANSPORTING THE
MIST DATA LINK ANTENNA
- THE FAMILY OF MEDIUM TACTICAL VEHICLES (FMTV2): TOWS THE MIST SAG
e. FULL FORWARD:
- THE FCV
- THE CSV
- THE MDV
- THE ISV
- THE IPV
- THE MEV
- THE MIST SAG TRAILER
- THE FMTV2
- THE EQUIPMENT TRANSPORT VEHICLE (ETV): HMMWV TOWING COMPONENT
60KW GEN
So, the trailer must have been set up to carry the
