M1123 Doors & Soft Top Fitment Issues
Derrinh
Las Vegas
I’m having an issue with fitting doors and soft top rails on my m1123. Basically it seems like the windshield frame is at too harsh an angle if that makes sense...explained further below...
Door Fitting Issue:
I have the fiberglass x-doors from Midwest military. On the front doors, I can’t get them far enough forward (toward the front of the vehicle) on the hinges because they get caught up on the top corner where the door meets the windshield frame.
Soft Top Rail Issue:
The rails fit fine between the b and c-pillars but they’re almost an inch off of the windshield frame mount (too long). And they’re definitely on the correct side as I’ve tried both to be positive.
These together led me to think maybe the windshield frame is at too harsh an angle but I’m sure there could be something else going on? Anyone have ideas or experienced anything similar? Maybe there’s a way to shim the windshield frame more upright a bit? If it’s helpful at all, my windshield frame has the quick release pins.
Any help is much appreciated.
M371954
Orlando, Florida
Derrinh, did this work? I am having a similar issue and my "Don't Break It" mind set is keeping me from digging in further. Need to get it set up.
M371954
Orlando, Florida
Loosen the screws on the inner hinge leaves and see if you can push the windshield until the rails fit.
NDT, I also read on another thread that you should start from the front and work back. Does that mean that The B pillar shoudl be adjusted before adjusting the windshield? I've started with the inside leaf bolts and it's has loosened the windshield. I'm concerned with I tighten them again that I will bend the side rails.
NDT
6,182
Camp Wood/LC, TX
Not sure how to adjust the b pillar other than something violent. Maybe you can put shims under the leafs if they are not flush anymore.
M371954
Orlando, Florida
Right on... violence is typically bad and gets expensive quickly (LOL). A standard aluminum plate should work fine in these examples I am guessing. In order for the to move the windshield forward, I will have to loosen both the center and right side brackets, then place the shims and tighten. I will give it a shot.
TNDRIVER
448
Cleveland,TN
Door Fitting Issue:
If your truck did not have a top installed when you got it I believe the A frame may have settled to the rear. I experienced the same problem with one of my trucks. I used some large clamps with the pads reversed to pry the frames apart. It worked but I also had to go back later when I discovered that the wiper contacts no longer made contact! While you have it apart it might be a good time to adjust the contacts. My two cents.
