M113A2 REV in Iraq
maddawg308
762
Appomattox, VA
Pretty interesting. Would be great for riot control use, I presume. Reminds me of the M113s in Vietnam with the firing ports in the sides, but those were a lot more lethal....
NEIOWA
127
NE IOWA
emmado22 said:
Less that lethal Claymores.. Very cool!
????? "Less than lethel" WTH Kinder gentler is PC nonsense
Rule 1. Do not emplace claymore unless you're prepared to fire, do not fire unless you intend to kill.
rmgill
14
Decatur, Ga
It's in the same vein as other less than lethal methods. My personal favorite is the Coil from a Centurion tank wired into a ferret on the hull for the high tension side. Run a chain and an insulated lead to the coil and when someone grabs ahold of the vehicle to climb on, they get a bit of a shock. ;-) 24 volts and a coil for a tank....if that's a bit of a shock.. :twisted:
