M1151A1 ECV LF Caliper Installation
rcamacho
827
Bainbridge Island Wa
Long story, I'm WIP re-installing the front differential after a rebuild.
The differential is in, RF brakes are done. I'm having difficulty with the LF caliper installation. There is not enough room in the forward direction to slip the caliper around the adapter/pads/rotor assembly. I'm thinking the differential may need to be re-centered (moved aft a tad) or the lower front control arm bolt may need to be removed in order to allow for the caliper to fit around.
Following TM 9-2320-387-24-1
"7-3. SERVICE BRAKE PAD MAINTENANCE (SERIAL NUMBERS 299999 AND BELOW)"
rcamacho
827
Wow.
Just spent 2 hours trying and failed.
Struggling to get 1/4” of clearance for the caliper to crossmember. Loosening the pinion mount and a pry -bar helped but not enough.
Looks like I’m pulling the cooling stack to access the mounts and recentering. Not bad, have to pull the stack anyway.
