M1152A1 rear axles 10K or 12K
Mogman
10,496
Papalote, TX
12K, a good hint is to look at your GVWR anything over 10.3K would be 12K unless someone changed them which is doubtful
Mogman
10,496
Papalote, TX
So you are stuck with ether rebuilding the ones you have if they are not damaged or ponying up the big bucks.
Mogman
10,496
Papalote, TX
Just be careful what vendor you get the boots from, there are some selling junk, one easy knock off is if they have "universal" clamps
Mogman
10,496
Papalote, TX
I would look at Kascar and HPG
Others may have suggestions.
I have seen some "real" surplus ones on that infamous auction site, the parts TM will give you the needed NSN numbers.
