M1165 AC compressor help
Gneumann3
Ventura County
Hi there, I am currently trouble shooting the AC on my M1165. The compressor was not activating, and I located a frayed wire (I believe it is 436) coming from pressure switch. As I looked for the other end of 436 (should lead to compressor), I noticed the compressor has a single green wire coming from the compressor instead of the two wires found in the wiring diagram.. After digging it appears the compressor in my vehicle looks to be the same as what the M1114s come with a single green wire. The green wire is electrical taped to 7J.. Any help would be greatly appreciated! Im not sure if this was replaced prior to being decommissioned, or if I can get this compressor to work. Attached is a photo of my vehicle as well as the two variants I found.
