Jeffphillips
- 6
- 3
- Seattle
I have an 8 amp battery drain as measured at the batteries. by disconnecting things I arrived at the conclusion it was the alternator. If I disconnect all the wires except #6 and the ground strap (wiring diagram excerpt provided in photos), the draw disappears (Photo 4649). When I reconnect the screwed connector (photo 4652) the draw reappears.
I don’t see the screwed connector on the wiring diagram; however I’m guessing the regulator is shot, but not knowing the function of the connector, that could be a very expensive guess.
can anyone either confirm this, or offer additional troubleshooting advice?
