M1165 issues
tgejesse
288
Maryland
Few issues while working on the 1165 today!
For the female door hinges, the standard hinge bolt does not want to thread in. I’m convinced it’s a totally different thread. Has anyone figured this one out?
And second, the center hood bumper is totally misaligned. Does the armor hood bumper land in a different location than dead center? To line up with the hood correctly the whole bumper needs to shift almost half an inch (possibly even a little more, hard to tell)
And the turbo CDR bolts are different than non turbo … but I’ll probably be able to figure that one out from the TM tonight LOL
tgejesse
288
Maryland
Hmm, the hinge bolts should work. There are 16 positions on the truck, have you tried others? Where did you get the hinge bolts?
I have. They thread no problem for the a pillar, but not the b pillar. It was a formally armored truck as you can see so not sure if that has to do with it
From western Kentucky surplus
Autonomy_Lost
1,485
Pennsylvania
My formerly armored m1151 uses standard hinge bolts for all 4 positions. I got the bolts from MAC Motors.
I believe those threaded holes are not used when the armored doors are installed, so there might be some corrosion getting in your way. Maybe try cleaning them out with some pentrating oil and a round wire brush? Maybe a .22 chamber brush?
Also, if I recall correctly mine were pretty tight. Perhaps they use a bit of a distorted thread design to keep them from coming loose.
Mogman
9,394
Papalote, TX
Is the hood aligned? Make sure the bumper is not "pushing" the hood into place, have another person hold the other side and hold it above the bumper and check the alignment, super easy to adjust.
Also with the hood open make sure the bumper is centered on the bracket it's bolted to.
tgejesse
288
Maryland
You know what. I don’t think it is. It’s getting stuck on the air filter box and the hood holder upper (LOL) doesn’t catch correctly. I will look tomorrow, good call!
Mogman
9,394
Papalote, TX
IIRC that thread for the door hinge is 1/4-20, again IIRC most of the "body" bolts are USS ( USA course thread) there may be exceptions.
tgejesse
288
Maryland
Update. No idea why the hood isn’t centered. Everything looks right. Spacing on the ECV grill looks even on both sides. Going to just bore out the bracket holes to slide it 1/4 inch and call it a day… LOL
as for the hinge bolts. Still no idea what’s going on. The threads look pristine because it was covered by armor. I don’t want to run a tap through it until I see what the correct size is
Mogman
9,394
Papalote, TX
Just look at the bolts you have, it is going to be "standard" thread.
If the threads look pristine then I would suspect it came with "interference" or locking threads to keep them from coming loose and running a tap through will defeat that intention.
Looking in the parts TM I see part number 5306013235535 for the bolt. that is a 1/4-20X3/4", that may not be correct for your application "length" but the threads will be the same.
