M116A Brake Shoes
Curtisje
693
Okinawa, Japan
I have an M116A2/3 trailer. Brakes were a little jacked when I picked it up from auction.
I don't know how they got the drum on over the shoe with it bent like this.
The part # in the TM is BSE10918081.
Edit: Yucca Valley, CA, NAPA figured it out in 5 minutes. Had them in stocks. Charged me 21.78 plus tax & core charge. Part number in picture below.
Jeepadict
676
Round Mountain, NV
They're a Dexter brake assembly. Everything is available from Croft or eTrailer except the backing plate which lack the holes for the brake cable. Both vendors stock the components.
Sent from my SM-G970U using Tapatalk
Curtisje
693
Okinawa, Japan
Neither of the recommended sites produces anything with the part # from the TM. I'll take the part into NAPA next week and see what they can do.
Jeepadict
676
Round Mountain, NV
@juanprado good catch, I totally missed the A1...the assembly caught my eye.
@Curtisje as I've heard NAPA is hit or miss depending on the skills of the guy behind the counter. Everyone I know has called Croft or eTrailer (emphasis on called) because their websites are not cataloged to the TM info as these parts are commercially available products cataloged by manufacturer part number. Call either of them, tell them you have "a military trailer with a Dexter hydraulic drum brake axle" and the rep will take it from there. They even have it all as an assembly from the backing plate to the drum pre-assembled if ya chose to go that route (tho the new backing plate omits the parking function) but you probably aren't gonna get all that at NAPA...but a guy could get lucky.
Curtisje
693
Okinawa, Japan
Thank you. That helps immensely.
