M116a3 types of beds?
maxtor
California
Has anyone seen a bed like what is on a M1101, on a M116 trailer?
I have done some searches and see the flatbed, or just the chassis. I am looking into using one of our M116a3 trailers to haul firewood, but to do that you need sides, preferably four foot sides. Has anyone here modified one to haul firewood?
quickfarms
25
Orange Junction, CA
It is called a M101A2 or M101A3, they both use the M116 frame
You could also just add stake pockets to the flat bed
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
We had a member here on SS put an M105 bed on a 116 frame. He said it worked well.
I can't imagine it would be very hard to fab some sides up to haul wood. No tube or sheet metal near you?
maxtor
California
Thanks, I did not know about the M101A2 or M101A3 having the same frame. I will look into those beds.
I have been looking into adding stake pockets. If I remove the outer removable fender on the M116a3, it would create a straight line for adding stake pockets and building side rails.
Thanks again.
maxtor
California
There is a place that sells stake pocket in our area. Thanks for the ideas.
quickfarms
25
Orange Junction, CA
I have found that 2x4 3/16 wall box tubing makes better stake pockets for regular 2x4's. A lot of the factory stake pockets are made to use special stakes and are very sloppy with 2x4's
1.5x2 0.90 wall box tubing makes stake pockets for the 3/4 an 1.5 ton trailer sides.
maxtor
California
Good information... Thanks.
maxtor
California
L.A. is about 600 miles south of us. We have a Home Depot here, that should have what we need. Also a Steel Supply that has stake pockets. I am going around today to get the needed supplies for the build.
Thanks for all your help and suggestions.
