M135 Front Hub #'s VS M135 Rear Hub #'s
Bigo1966
Lafayette Colorado
So im still on my quest to run singles on my M211.
My next question is do the M211 and M135 run the same front hubs? If so are the rear hubs on the M135 the same as the front hubs on the M135? If that is true cant i just get front hubs off a M135 and put them on the back of my M211?
Just a thought.
Orion
G744
3,703
Hidden Valley, Az
RE: M135 Front Hub #
IMHO, all hubs on the G749 trucks are the same, front & rear. They did not "flip" hubs on these trucks, just used different pffset wheels.
dg
panhapp
OK PANHANDLE
In doing research I find these old threads that have inacurate information in them. I figure that when someone tries to search and finds them it really makes it confussing. I don't want to step on any toes as I just joined up but I haven't seen any accurate info on this, but I may have missed it.
From what I find in the manuals the hubs front and rear are the same on the 211s and the 135s.
On the front everything is the same except the wheels.
On the rear, to change from 211 to 135 you do flip the hubs. You also have to change to a 135 brake drum back. The studs and wheel nuts are also different.
I am going to have to do this so I have been researching it. Hope this will save someone some time.
Pan
hippiedude
Granby , Ct.
Why would you have to chang the brake drum backing plate ??? And why not front lug nuts on rear studs , just don`t use the rear thimbles ...........??? What am I missing ???
panhapp
OK PANHANDLE
For lug nuts you do use 135 or front 211 or 135 nuts.
Look at fig. 180 on page 286 of tm-1819. The top half is of a 211. The bottom half is a 135. You can see the dual wheels at the top. If you look at the brake back you will see that the 135 has a deeper dish or offset. This is so the drum will line up with the shoes when you flip the hub. I think you could use the longer 211 wheel studs but to be correct you would use 135 studs or front studs.
Pan
butch atkins
Fountain Inn SC
ORD 9-G-749,the PLATE,Backing(what all off the springs,adjusters,shoes etc bolt to)are only in left,right for ALL models,as are ALL the studs,remember that the BRAKE DRUMS are 2pc,the difference is there between the M 135 and the rest of the series is in the BACK PLATE that bolts to the DRUM,way to many part #s to list but thats the way the ORD 9 lists them,also difference between HUBS for M 135 and rest of series,hope this helps,all you need to figure this out is the ORD 9-G-749 manual
butch atkins
Fountain Inn SC
Hubs drums
maybe my post wasnt real clear,M135s run different HUBS and BACKS of HUBS,and different offset RIMS to obtain their unique ability to run the 1100/20 tires,dont think you can run the 1100/20s on an M211 cargo body and expect any kind of articulation out of the rear axles without tire bind,there is a reason M135 cargo bodies have those huge wheelwells in them,And yes ALL of the STUDS are the same for ALL of the G-749s.The offset for the M135 wheels are 5 1/2" and have the chamfer for the lug nut on one side of the rim only.The rest of the wheels have a 6 3/16" offset to them,with chamfers on both sides of the rims ,so that you can use them in any position on the dual rear wheel models,good luck on finding the correct parts if you want to put singles on an M211.I do know of someone who has a complete set of M135 rims if you wish to proceed with this project.PM if you are interested. Good luck to all on your projects
panhapp
OK PANHANDLE
I wasen't infering that you didn't have to chang beds (frgured that was a given). My manual givs part# 7411472 for all 211 and 135 hubs.
brake back for all 211 and front 135 = #7413231
brake back for rear 135s =#7413232.
Pan
panhapp
OK PANHANDLE
Butch I reread your post. Iam not talking about the backing plate on the axle.
I'm talking about the two piece brake drum. The manual calls the center part
that mounts to the hub the back. this center of the brake is what is differant.
the 135 has ( on the rears ) a deeper offset so when you flip the hub the drum still lines up
with the shoes.
Pan
Stan Leschert
90
North Vancouver, BC, Canada
BTW, while playing with lug nuts on a 135/211 , remember that some were RIGHT and LEFT handed thread. Look on the end of the stud (L - R) to tell you which way to turn.
This ways not directed at the previous posters ( who know) ,
but at anyone else who reads this thread.
hendersond
29
Galesville, WI
Does anyone know what size socket I need to buy for the spindle nut? I'm looking at Superdave's picture item "B"
Dan
butch atkins
Fountain Inn SC
WRENCH,wheel bearing nut,octagon,( 8 sided ),3 7/16 opening,3/4 sq.-drive with 2.072 tubular pilot ,5 in long,picture is on pg 23 of TM 9-1819AC ORDANANCE MANUAL,basically it is a 3 7/16 8 sided socket,you can get a cheapie at any truck shop,the original has a pilot on it that goes up in the axle tube so you dont slip the socket off of the bearing nuts ,the nuts are only about 1/4 thick,PART # 41-W-3825-66
hendersond
29
Galesville, WI
Thanks Butch. I did see it in the manual, but did not believe it. The pilot threw me. Makes perfect sense now. Thanks again. [thumbzup]
Dan
butch atkins
Fountain Inn SC
BTW ,I have BOTH of these wrenches (sockets),the only difference is that 1 has a 1 7/8 in. long pilot,the other has a 5 in. long pilot,i got them off Ebay at a really cheap price.dont think anyone knew what they were,sandblasted them and painted and the part #s were the same as the book,and they work so much better than the socket i bought at the truck shop. :D
