The PTO is attached to the transfer case on the M135 / M211 series truck, so the RPM of the PTO would depend on the the engine speed and transmission gear. Usually the PTO was intended for use while the vehicle was stationary (transfer case in neutral). The PTO can be engaged simultaneously with the transfer case for vehicle movement. The RPM of the PTO and engaged transfer case can not be separated. Remember that the hydromatic tranny has both high / low ranges, the transfer is a single speed design. We have a M215 dump truck, the dump mechanism hydraulics are controlled by the PTO. It is difficult for me to raise the dump bed and control forward movement when attempting to spread gravel / dirt.
