m135 spare tire mount
WillWagner
2,729
Monrovia, Ca.
Why did they change it to the POO POO thing on the M35? Looks lots easier.
butch atkins
Fountain Inn SC
gmc spare tire mount
dont know if you guys have noticed ,but the spare tire carrier is removed on my m211,why ? because if you look under the posts under my name with the pics on this thread you will see that in both pictures the reason that i am stuck is because the #*^! spare tire is what is keeping my truck from moving because it hangs way low and gets hung on anything that you think you will be able to drive over,it is a good way to carry the spare ,and really easy to change a tire with this setup but i woulds advise anyone who is going to trail ride agmc ,remove the entire assy,this is the voice of (bad) experience speaking,if your going to be an asphalt queen leave it on ,if not put a spare or two in the bed ,and a comealong ratchet cable in the bed of the truck to get a tire into the bed if you have to change it ,and remove the entire assy,just my 2 cents worth from truly bad experiences,good luck to all on your projects
butch atkins
Fountain Inn SC
low rider spare tire mount
to put it in proper pespective,look at the last picture of hippiedudes truck in this post,on level ground for an m211 it is only 13.5 inches to the bottom of the tube for the spare tire carrier ,it is 24 inches to the bottom of thecab step,and 28 inches to the bottom of the fuel tank,an m135 sits about 2 inches higher because it runs 11.00-20 tires ,so not much difference at all ,still hangs way to low for off roading,i just went and took measurements with a tape measure of my m211 thats where the numbers came from,and then you have the problem of a 44 inch diameter tire laying horizontally underneath the truck ,when i go on a road trip i do put the tire and carrier on the truck it only takes 4 bolts to take it on and off,had to leave a flat tire on the trail once because i had the spare in the bed,but forgot the cable come along to get the flat back in to the bed,went back later and got it ,learned the hard way on that trip,good luck to all on your projects
