M135 Transfer case rotation HELP!!!
985johnm
covington/la
I installed a M135 banjo style transfer in my toyota with 1 ton axles and I find out the rotational direction of the front output is opposite the other 2 outputs in the rear. Can anyone give me a diagram / exploded view of the transfer? does anyone know if I can rearrange internal to get the front shaft to turn the same direction? or can I turn the rear center output around and face it out the front. This would also solve my problem. Better yet does anyone manufacture a longer center shaft that would give me a fourth output in the front rotating with the rear 2. Thanks john
gringeltaube
Staff Member
2,396
Montevideo/Uruguay
TMs 9-1819AC (1 to 6) found in RESOURCES - TECHNICAL MANUALS on page 6, should have all the info. Only problem: 93MB each! Takes me 20' to download...!
G.
