1951 m135
Wow Stan, to be included with that group I'm going to need to study. Thanks.
Stone....I'm on the bottom edge of the learning curve with the 135 but have gone through the "catastrophic" potential failure points of the truck and have an idea what you might be up against.
If you plan to drive on "public roads" you will need to focus on brakes and
steering. I've replaced or repaired the entire brake system with professional help.
Pro help is expensive so total "stopping" investment for me...so far...over $2000.00.
Steering....drag link, tie-rod, spring mounts, steering box, steering wheel were all borrowed off of donor trucks. $1000.00
Seals, bearings, U-joints $2000.
All fluids.... $750.00.
If you're doing the work yourself it will cost much less but 'safety' still needs to be checked off the 'to do' list.
The truck is a 51' so check data plates and/ or passenger frame behind front
wheel for the ID number. You may have an early model or even one of the first
ever built. That can be important.
I wouldn't start an engine until air breather (mice), fuel (rust) and oil have been removed and replaced which is a catch 22. You want to see if it runs and moves but just firing it can pull crap into the carb and pooch fuel.
The kids are right:
1) Trani
2) Motor turns (could be the 270???)
3) Brakes
4) Steering
5) Tires
6) Loose/ broken suspension
Buy low and plan to replace everything......It's 61 years old.
