- 55
- 5
- 8
- Grangeville, Idaho
M146 6 ton shop trailer in time capsule collectable condition. Reworked by VSE Corp. in 3-08 then moth balled. Some aluminum repair patches were added during the refurb process. The floor is in perfect shape with no rot. Bought this back in 2011 at auction from the Fort McCoy military base in Monroe, WI.. Started prepping it for 1 3/4" foam board insulation. The wall panels are removed and ready for your personal touch with custom wiring, outlets and lighting.
All the window bug screens are new and ready to install. 900:20 non directional tires with spare. Dual handle crank landing gears operate independently on uneven surfaces in the field. Push up black out windows panels. 2 of the black out window panels were lost in transit by the carrier. The 2-back door black out window panels can be used or just simply fabricate 2.
Length 22'-6", width 8', height 11', weight dry 7330 lbs.. Pull it with your flatbed fifth wheel set up with air or single axle tractor. Considering its size it's easy to maneuver and park. This is the ultimate compact off-road trailer for expeditions. Built solid like a tank with no frame flex in transit or off-road excursions.
Still have the original government issued title. Available for $12,000.
Google Drive link with additional images.
drive.google.com
M146 SHOP TRAILER - Google Drive
