M151-A2 Engine
cstinson
Streetman, Texas
I have a M151-A2, W/Ropes, that I am about to start restoring. It has a running engine, but it is weak, and I was wondering if anyone knows if there are new Long Block engines available. Is it easier to overhaul existing engine? Attached are some pictures of my MUTT...IMG_0365.jpgIMG_0339.jpgIMG_0352.jpgIMG_0349.jpgIMG_0345.jpgIMG_0347.jpgIMG_0346.jpgIMG_0336.jpgIMG_0337.jpgIMG_0368.jpg
Warthog
232
OKC, OK
Rapcoparts.com in Bowie TX or redriverparts.com in Hooks Tx may be able to help you out.
cstinson
Streetman, Texas
Thanks.........Warthog. I'm new to this Website, but I am catching on. I have some pictures that I will post, but I need my daughter to help with this. I am an older Vet, and am not a Computer Wiz by any stretch.
cstinson
Streetman, Texas
I finally found the Tag with the Serial #, and Body #, on my M151-A2. It was on the Transmission tunnel, under the fuel lines, as others have described. The SN# is: 11639700, and the Body #, which is directly under the SN, is: B151-6420. Can anyone tell me if this reveals the Year of production? I am very excited to have found this tag, as I have read in this Forum that it is necessary to apply for a Title. Any help would be appreciated.
mutt_kahuna
M151 country,Nevada
Aloha...there are usually quite a few people/dealers with low mileage complete take-out A2 powerpacks....I'd take your current engine out as a spare and look for one of the low mileage t/o's...MUCH cheaper then rebuilding....
cstinson
Streetman, Texas
Thanks..........I'm going to pull mine apart ans see what I have, and probably overhaul it as a spare, as you advise. Just spoke to a guy in St. Louis that has access to some of those PO engines.
cstinson
Streetman, Texas
Thanks........I'm thinking about buying a takeout to install, and overhaul mine as a spare. I will call you and discuss my options as far as complete engine, long block, transmission, etc.
vtdeucedriver
Vermont
Its the quickest and easiest way!! Plenty of dealers in TX for those engines so no need to shop half way across the country. Come on over to the www.g838.org
We will be glad to help!!
