M151 door frames
Whiteclam
Kent/WA.
Got my NOS M151 door frames today and I have never installed any before. Everything is straight forward except where the upper windshield/ top canvas bow comes together. There are two holes on the end of the bow frame an inch apart. Does the vertical door support connect to the second hole? Can anyone post a picture of how this should be connected?
majorhitt
Dallas Pa.
Ok Whiteclam I looked for the info you're after. I have no photos that close. I tried to find my TM , But it's just too cold to look for a while. I can't remember two holes. Is this the vertical rod that also makes up part of the hinge? This is going from memory, The vertical rod sits in a pocket just above the ax bracket, up to the windshield frame to a triangle bracket. This triangle bracket has a hole in it. From the bow frame a small folding rod with a pin at the end goes thru that triangle bracket along with the vertical rod. This horizontal folding rod also has flat area with a hole that the fear post for the door pins into, this also sits in a pocket just above the other ax bracket. Could you post a photo?
majorhitt
Dallas Pa.
I found a photo of a 151 with the rod I think you're talking about. It's the rod from just above the ax to the top of the windshield.100_1285.jpg
Whiteclam
Kent/WA.
Thanks guys. There wasn't two holes, as the pin was attached to the bow frame rod. I see now where the door frame rod attaches to the triangle part of the windshield with the bow frame pin completing the connection of all three parts.
