M151 Horn beeps by itself
stuinnh
Derry, NH
Hi all!
My mutt's horn goes off without me touching it. Goes off when turning or changing gears then stops. This just started happening. Any ideas why and how to fix it?
Wildchild467
57
Milford / Michigan
If its like most horn systems on these MVs, I take a guess and say its a chaffed or worn wire in your steering column. Your horn button is on your steering wheel, right? If so, somewhere the wire comes out of your steering box for your horn. This is a common place for wires to break for horns. That is just where I would start looking for a wire that is worn through the insulation and grounding out, causing the horn to sound.
combat32
106
Booneville AR.
What he said above, my first deuce would honk every time I turned a corner, neat safety feature but I replaced the wire and that fixed it.
