ODdave
- 38
- 0
- lansing michigan
so i have searched and not found anything about this. there is curently a '66 m151 in the shop where i work and both front and rear transfercase outputs are leaking. i asumed it was just the seal but upon further inspection, both shafts had a considerable amount of movement up, down and side to side. i think there is a bushing inside that is worn out. is this true and if so is it dificult to replace? thanks.
