mutt54
- 0
- 1
- California
Hi there,
I accidentally removed reverse shifter arm pivot - hex bolt on left side of transmission case.
I`ve put it right back in, but I do not know if it went back through the hole in the middle of shifter arm.
Do I have to open the transmission or is there any other way to find out if reverse shifter arm is out of alignment?
Thank you,
Mutt54
Thank you,
Mutt54
