cry102
- 0
- 0
- phoenix, az
Hello
I recently purchased an M151A2. I have driven it around the block a few times and noticed the voltmeter reading in the high white. A couple days ago i wanted to take it for a long drive and couple miles down the road i stoped to get gas and smelled smoke. I did not know where it was coming from so I continued on my trip. another couple of miles down the road i noticed the voltmeter was reading above the red indicator so I pulled over and opend the hood and found the generator smoking real bad. what would cause this problem and should i replace it? If i replace it should i go with a generator or switch to an altanator. the generator is a 60amp. Thank you for your help
