- 5,580
- 345
- 83
- DESOTO, KANSAS
I forgot I had them but back in the DRMO days I got 4 large crates that had a large aluminum skin box shaped floats. The back was open side and filled with foam, there are slots cut into the top and bottom edge to mount it . There was no writing left on the box. Did the goat have an add on float or were these maybe for the M113 surf board .
Ok here are pictures, the float or whatever is 5'8 1/2" long, main body is 6 1/4" thick and 25 1/2 high, edge of mounting flange to flange is 30 3/8" the metal is 1/4 thick. There are eight 1" and two 3" tabs cut into the top flange and only 3 elongated holes in the bottom. You can tell it been in the shed for years, the other 3 are still banded in plywood boxes. So any body got an idea??
![float 069.jpg float 069.jpg](https://www.steelsoldiers.com/data/attachments/82/82494-2d5056c1f35d9d42ce39e493ce28593d.jpg)
![float 065.jpg float 065.jpg](https://www.steelsoldiers.com/data/attachments/325/325224-74fd58964346b891700ed29c8c7179ae.jpg)
![float066.jpg float066.jpg](https://www.steelsoldiers.com/data/attachments/82/82491-c8eb78479fb65264e08de9897abd9acd.jpg)
![float 068.jpg float 068.jpg](https://www.steelsoldiers.com/data/attachments/325/325220-cb8cfaf34499304a7a248860f837be74.jpg)
