M19A1 8 TON TRAILER DOLLY CONVERTER
rumplecat
221
North West Arkansas
Anyone know the tongue weight of one of these? I would rather tow and trailer, but tongue weight will make the difference.
James G.
rumplecat
221
North West Arkansas
Thank,s for the reply but I hope that is gross weight! I need the tongue weight, the downward pressure the dolly will put on my bumper hitch.
James G.
No.2Diesel
11
Huntington, NY
I don't think it would exert any significant tongue weight. Towing an unloaded or loaded dolly converter is like towing a log splitter or a cement mixer. I can't imagine any more than 50lbs. if that.
You should be fine.
jwaller
19
Columbia, SC
I can pick up the tongue on the dolley I have so it cant weight more than 2-300 lbs. it has to have that kinda weight or it would swap badly behind my trucks and it tracks well.
citizensoldier
17
Northern Michigan. Smelt City
If you are going to have it on a downword angle to a bumper hitch !!! They are heavy and bounce around allot.. There is not allot of tongue weight at the level position.. I had one of these shear a grade 8 equilizer hitch pin.. So that should tell the story on the pressure.
rumplecat
221
North West Arkansas
I found out the level hitch weight is 250 lbs., downward angle would increase that a good bid I would think. My hitch will load level up to 800 lbs, but I think my Armada is lower than your pickup.
James G.
rumplecat
221
North West Arkansas
All to no avail, outbid again, most went for over $600, of course it is hard to tell since GL no longer adds them to your bid history.
James G.
