Gb1
- 0
- 1
- Sheridan/OR
I’m writing to see if anyone on the site has even made a hitch convention for a M200A1. I would still like to be able to tow the max weight of the Trailer which is ~7000 lbs on a 2-5/16 ball. On the trailer there is a (removable) standard MIL lunette ring which looks to taper fit into the front of the trailer receiver. Even with the trailer jack lowered to the lowest point it is too high to connect to a pick up truck. If I lifted a pintle hitch on the truck I believe It would interfere with a lowered tailgate.
Has anyone created a custom dropped ball hitch to fit to a tapered steel shaft that mounts like the lunette? This would allow me to swap between pintle ring or ball. Or has anyone simply welded a dropped ball hitch to the face of the front of the lunette receiver with the ring removed? I don’t want to make this too complicated...
Also any other suggestions for creating a 2 5/16 inch ball receiver to the M200A1.
