M200A1 trailer - lights and brakes
Gary27701
Maryland
Hello,
I just got a MEP-805B mounted on a trailer.
I have 2 questions.
- Are the 24 volt lights plug compatible with 67, 97, 1156, and 1157 12-volt bulbs? I think that they are. Hopefully the trailer has the LEDs.
- If there is no air pressure, am I correct in thinking that the wheels are free to roll? Hence the need to chock the wheels.
Thanks!
Gary
Coug
4,235
Olympia/WA
Hello,
I have 2 questions.
Thanks!
Gary
the bulbs use standard base types, so no reason you can't do the 12V version. I've done it and I know others have put multi-voltage bulbs in so it can run off either 12 or 24V depending on what's pulling it.
I can't confirm on the brakes, but pretty sure without air they aren't locked to chock blocks are important.
