M200A1 Trailer Question
uscgjason
Alaska
I'm getting ready to pull a MEP 804 B trailer system to Tennessee from Alaska. Anyone know what kind of speed this trailer can handle?
Thanks.
MWMULES
349
DESOTO, KANSAS
As long as the tires are good and you have serviced the wheel bearings is will go Hwy speed.
drivebymashing
51
North Carolina
Id probably just check grease and check for play in the bearings. The tires are rated for like 55mph. Ive pulled trailers with the same tires at 70 with no problem. Thats an incredibly long drive...
Guyfang
23,987
Burgkunstadt, Germany
Thank you. Does anyone know where to get wheel bearings and such for these monsters?
Look in the parts manual, get the part numbers and buy some. This is not an unnormal bearing. Should be able to get some at truck parts place. But why get new bearings?
If it were me, and I was worried, I would pull the hubs off and regrease and install it all again. Follow the TM instructions. I have driven a million miles towing the M200A1 trailer at speeds of 30-70 mph, and have never been let down by the trailer. This is one of the few I wold trust on a long haul.
topo
256
farmington NM
Wheel bearing race # 7411377 wheel bearing # MS19081-112 nut #7411379 ( two each side ) lock for nuts #7411378
Don't forget wheel bearing grease
Universal City, TX
I'm using a 1 ton Chevy crew cab.
The reason I ask is, depending on which version of the M200A1 you have (dualed, single wheeled, etc) most states require you having trailer baking ability for trailers over 3000 pds GVW. That's a long distance to drive not able to control braking and possibly not in compliance with state laws. A lot of people ride dirty in MVs, not following laws, licensing requirements, etc. Just make sure you do the research to see what the laws in the stated you are going through. Safety first.
uscgjason
Alaska
Thanks it wasn't something I thought about and the air system on it will just be disabled so it should free wheel, but it is a single wheel trailer.
uscgjason
Alaska
I remember reading at some point that it is equipped with an air brake system it is required to be used. Don't remember where I read that though.
Yes I'm sure it is required to be used at some point I may have to look at a conversion or just selling the whole thing and doing something else. I hadn't planned to move to Tennessee so this is a new development
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Its only about 4000lbs total. I'd pull it. If your worried about the 3k weight limit some states might have, put the genset in the bed of the truck and tow the trailer by itself. I'd let some air out of the tires so it offers a smoother ride.
Just my opinion.
porkysplace
1,493
mid- michigan
Just my opinion.
Even at 4000lbs if there is any kind of bad weather it could be iffy crossing the mountains without brakes.
gimpyrobb
27,786
755
Cincy Ohio
Point taken, I haven't driven west much. I'd just load the genset in the bed then.
This is specifically the reason I keep my purchases to within a 4hr drive!
sigo
Lieutenant Colonel
406
Leavenworth, KS
Taking the ALCAN or a ferry? Going thru the mountains in the Yukon and BC is no joke. If you’re towing the full PU-802 without brakes take it slow. Very slow. And watch out for critters. Elk, moose, bison, bears, etc have no issues with standing in the road. Stopping quick with that trailer behind you may not be an option.
Guyfang
23,987
In the late 70's, a friend of mine spent 8 months in the hospital when a moose ran out in front of his VW bug. He might have been a little sleepy also. He was coming down from Alaska to be stationed in Washington. That was the end of his military career. Probably hasn't gotten any better in the last little bit.
rustystud
2,972
Woodinville, Washington
If anything the "critter" incidents have risen out here due to the encroachment on their habitat. Mostly just stupid deer walking down the center of the road. Though the mountain lions have started using the roads also. Probably following the deer.
