M211 Air Pac Piston
hk7777
Dalton Gardens, ID.
Ok we all know the allusive air pac is a pain.
I am in the middle of re-building or replacing the one I have.
Upon pulling the unit and dismantling I found that the internal aluinum cup or piston had the cup broken out.
Has this happened to anyone else?
I am contemplating making a dozen or so pistons.
Does anyone see this as being a needed item or not.
1,174
Are the internals (pistons) the same as an M35?
tjmilitary
Grant Park,IL
I dont think they are the same. Which piston are you talking about, the large 3"-4" one or the small one that pushes the brake fluid? I think the small one is the only gasket different from the 5 ton air pac kits.
BugEyeBear
Eastern Georgia
nopics
I'm gonna need to do an airpack rebuild down the road on my M211...
So PICTURES and descriptions of your disassembly/assembly would be MUCH APPRECIATED!! [thumbzup]
Keep us updated on your progress!!
Thanks In Advance!!
-Bear-
