Havasurat
- 0
- 3
- Lake Havasu, AZ
Im stuck here big time. Rebuilt master cylinder replaced wheel cylinders. We know the airpac is bad.. How do I bypass the aipac. I need to be able to move the rig.
We know the pads are off this rig we didn't do that maybe I need to take the drums off and make sure the pads were put on properly. Right now the air pack is completely out of it I'll check the drum issue four pad orientation first and I'll take it from there I will get that done in the a.m. and update the board thank you.USMC-008 has a thread about the check valve that IS NOT supposed to be in the G749 MC master cylinder so let's hope that's where pascal is messing with you. If he doesn't chime in I'll knock on his door for clarification.
We have turned the brake adjusters back in the bush to nurse a truck home but deck them on public roads. When you back them off they may rub a little and warm up but you still have brakes. My brakes work well with or without air so those massive brake springs pull the pads away and squeeze the wheel cylinders fairly easy. I have looked at a few pads that weren't assembled correctly and resisted the return springs. If the pads aren't floating properly they can stay planted once a guy pushes the pedal.....but not all at the same time.
This should be easy so we'll follow-up MC info for you.
Mico switch is disconnected.Make sure that the Mico brake is switched off (temporary parking brake). The Mico switch is an electrically applied check valve that prevents the brake fluid from returning to the master cylinder. I know of a few owners who have completely disabled the Mico switch on their trucks to prevent problems.
I have left the shop for the weekend I will update on Monday with pictures. And thank you for the link thereCan you show us how you bypass the air/ hydraulic cylinder? Pictures at eleven?
Here is the latest air pack info. https://www.steelsoldiers.com/showthread.php?70703-M220-AirPak-rebuild/page4
