M270A1 how much weight would it haul?
jasonjc
283
Gravette Ar.
Per the TM it's called a "12 ton" trailer , max load is 40,000lbs and weighs in at 17,500lbs.
Hope this helps.
R Racing
St. Leonard, MD
Its called a 12 ton for off road use . On road use is 40000 LBS When I was getting mine beavered. The company that did it builds trailers and they said in there opinion 40K was under rated if you compare it to trailers made today.
