Jeeagle
- 0
- 6
- Chattanooga, TN
We have a A5 variant mule at the Museum I work at and I have been fighting it consistently.
When we got it it ran fine but slowly started to get extremely temperamental. Start misfiring and back firing through intake and back firing out the exhaust quite nasty like.
We took the plugs out and cleaned them and I re timed the Mag according to the several info threads and website I have seen. Ours seen happy with the V marks lined up versus being off a tooth. For approx two weeks the mule ran perfect no surging no bucking just perfect.
Now, it is going back to the misfiring and back firing out through the exhaust and intake again. I verified the timing again, and adjusted up and down to no effect. We checked the fuel filters and found crud and cleaned it all out. I checked the fuel return line to find no blockage and plenty of fuel flow.
The carb looks new with paint marks on the adjustments. I haven't really messed with them as I have not found alot of info on what exactly needs to be adjusted.
Other info...
I have been using Non Ethanol Fuel, with some lead additive (was suggested). Oil has no gas smell in it. Filters are clean and tank has been drained and refilled with fresh fuel.
I have noticed there is discoloration in the muffler where it looks like the exhaust is extremely hot. To me this shows a lean running engine but with no major info on carb adjustment I haven't been able to look into fixing that if that is not normal. I am going to pull the plugs again soon see how they are and post on here if needed.
Any help is most thankful and I am also looking for any contact info on mule supplies (parts) if possible as well.
Other info...
