- 8,468
- 2,584
- 113
- Monrovia, Ca.
We need to get this ready for a holiday event or Vets coming up next weekend. It hadn't been lit off in a few years. Dumped fuel in it, checked the brakes, no fluid in the MC but clean, no rust. Put a battery in it, cranked it and it fired right up! Didn't run so well though, the last time I remember this running was at an event at County Park in Arcadia 10 or so years ago, I remember it running poorly, but we looked it up and the notes said it ran good. Moved it to the shop and took a look at the brakes. No leaks seen at the wheels, maybe an old small leak at the MC pushrod. WTH, put fluid in the MC and used my trusty Recovery4X4 bleeder...GOD, I love that thing! Thanks Kenny! Bled the system, no air, no leaks, good pedal! I love it when things are fairly simple!
On to the poor running. Looked at the points, they were new-ish, but were not sitting correctly, only 1/2 of the pads were touching. Used a points file and cleaned them up and re set the gap from the .030 where it was to a snug .019. Fired it, popping out the exhaust, black smoke. Hmm it had more than 1 issue. decided to start electronically. Looked at the number on the points and looked in the parts bin, Cool, there were a few sets of points/condensers! Put those in, moved the engine to where the rotor was pointing at #1 and looked for the timing mark on the flywheel, moved the engine back and forth, no mark seen, Oh well, time by ear! Put the points in, gaped them and fired it, moved the timing, Still pops and backfires out the tailpipe but the distributor needed to be moved ALOT to make run even the slightest bit better. The whole tome it is running, the WP is leaking slightly. The gland nut has a split in it....
Decided to look at the carburetor. Attempted to adjust the idle mixture, no change. completely removed the screw, no change, no vacuum! Something is amiss in the carb. Asked Craig if it was OK if I removed it and gave a look see since parts are hard to find for it. He gave me his blessing and off it came. Full of .....stuff. Pulled everything out of it, cleaned all the passages and jets and then found the issue. The gasket is hand made, the hole for the idle circuit was not made into the gasket. Pulled out some new gasket material and made a new gasket, put it all back together, fired it off, MUCH better!!. Adjusted the carb, better, messed with the timing, much more better, but, the distributor is not aligned with a lock down hole, I think it is off a tooth.
The engine runs fine, so, we have another WP, need to get a kit to rebuild it. Decided to leave it as is for the event. When it is back at the Museum, we will get a kit to rebuild the WP, the distributor needs to come out to do the pump, so we can re TDC it when we do the pump. As for the timing mark, I don't know if the flywheels can be put on correctly or 180 degrees out or put on any way, guess when it goes back together we can try checking timing using #3 cylinder if the flywheel can be put on only correctly or 180 out, i'd rather just time by ear. Took it out of the shop and drove it around the compound, has good acceleration and, most importantly, it stops
On to the next project!
