M35 Batteries
wiggall
151
Lenore, Id.
I have a question on the M35. Should the front, and rear batteries be switched around? My front battery seems to be the one that is always going bad.
simp5782
Feo, Fuerte y Formal
9,338
Mason, TN
Do you have something wired into that side that is an accessory? Like a 12v item? radio? Fan? lights?
Gralmk
52
Attleboro, MA
Mine are 4 years and still going strong. Plus in 30 years of service, we never switched them. Only once they were dead, and it was usually both.
Agreed. If your having that issue for some reason, I guess switching is better than killing one!
1,127
I've owned lots and lots of deuces now for 12 years without interruption. Never have I had an issue with one or the other battery failing.
If you've had 2 or 3 batteries fail, it's a statistical anomaly or coincidence, unless you were pulling accessory power off one then, which you said you aren't.
DeadParrot
47
oklahoma city, ok
Do you have anything by the front battery that would cause a temp difference in the battery while parked? Block heater, heat lamp etc? Lead Acid batteries are fairly sensitive to temp differences from one part to another. If the top is warmer then the bottom, you can get internal self discharge due to the warm parts having a slightly higher voltage then the cooler parts. It where the old "don't set them on a concrete floor" tale originated. It isn't the concrete that causes the problems but the temp difference between the floor and air.
glcaines
2,523
Hiawassee, Georgia
Battery life can also be related to the quality of the batteries, although I don't see how front to rear mounting would be impacted. I'm a firm believer in 6TLs from Interstate. I've had fantastic luck with them. They have such a large capacity that starting, even in cold weather, doesn't put much of a strain on them. I also run a battery minder 100% of the time when not driving my deuces.
Bill W
44
Brooks,Ga
I always change out batts in sets, I do this on my F-250 as well as the deuce as one will usually damage the other as its failing and then in turn damage the replacement battery.
emr
25
landing , new jersey
OK U say FRONT batt, I am going to talk about the FIRST batt in the charging line here,,, YES! Charging batterys are like filling a pool, the charging system would have to over charge your first batt to fully fill the second, The resistance from the batts that turn the charging system off is set as NOT to over charge the first batt, Oh yes it is,. So the facts are as U suspect the Batts down the line never fully charge and there fore sulphate faster than the first batt,,, The charging systems in our and all trucks are NOT smart chargers, Batterys in ALL military vehicles should be pulled cleaned and fully bench charged and ROTATED and re installed if you want MAXIMUM battery life,At least once a year/
Simple TRUE facts, U can charge em in truck with a 12 volt charger on each and do not have to disconnect anything, between rotations, Batts will start a vehicle in good running order at 70 percent full, so it gets deceiving that people think there batts are full when they are NOT! ...
U noticed something many never get, Good call, Oh and when U need a batt, U do not need to buy 2 , if U only need one, almost ALL of these trucks are running with lower batts down the line so to speak, Just put the newer in the back, and rotate em, Now This is assuming U know how to test batts , and If the first is holding its current in the test No reason to replace it. I try hard to rotate em twice ayear, I have more than 10 years out of older Mil batts a few times,
Remember when your batts go prematurely , Its not the batterys fault, Its like everything else 90 percent Human error :)))))))))
As said above about never having a batt fail, I believe is not the question, The second and last batts in line do not fail, But do die faster than the first because of increased sulphation, Most see a batt die and replace both, And do not realize the second or last batt is the one dying first and putting more strain on the first..
Using a 24 volt charger is fine , But if U want ALL your batts FULLY charged u MUST charge each of them with 12 volt chargers, remember filling a pool. The first batt will stop the charging process so not to over charge the first batt, and leave the later batts wanting,
Oh and remember these batts need at least 13.6 volts to fully charge , a good variable charger does this, Trickle chargers will NOT fully charge these batts even though they will say it is, BECAUSE The resistance level is telling the charger it is full, It is not, but it will run the truck , But will sulphate faster than batts that receive regular FULL charges, All Facts.
frank8003
4,983
Ft. Lauderdale, Florida
I hate buying batteries.
Some have not battery problems because every wire terminal + and - was refurbished up to new specs.
Take it all apart and fix it as good as can be then watch the system work properly without cooking off one or the other. Whatever you can do to make the little electrons move around would be good. Yes, swap back and forth. Hey, I tried to help Her as much as I could.
Clean, tight, no cracks, etc. Can't hurt. Fix up both ends of every connection.
battery box IMG_2220.jpgIMG_2768.jpgIMG_2758.jpgIMG_1665.jpgIMG_1654.jpgIMG_2759.jpg
rustystud
2,796
Woodinville, Washington
That's what I run also. I have had no problems from them in 5 years now.
rustystud
2,796
All that you said "can" be true, but (there's always a but) if both batteries are the "same" and bought and installed at the "same" time they act just like "one" battery if the connecting cables are good and of the proper capacity. Working in the trucking and bus industry for 4 decades I've seen many systems. Some good, some bad but if there installed correctly they all work fine. At the transit department where I worked for the last 25 years all our buses had 4 batteries connected in series/parallel . At no time did I ever hear of a battery going bad from "under charging" because it was the "last" battery in line. Our batteries were all the same make and model and all cables and connectors where "above" capacity needed. I check my batteries every year, and every year they check out fine. Of course I use 4/0 welding cable to connect them and they are exactly the same batteries.
I forgot to mention I use a $180.00 "Refractometer" to check my actual battery fluid. I don't believe in using electronics to check battery fluid.
rustystud
2,796
I should also mention that the transit agency has over 300 "Hybrid" buses. That means there is a "huge" battery bank on top of the buses. These battery banks are 2 cell units (measuring 4" x 4" x 12" ) connected together with copper alloy links. There is 50 units all together. The weight of the whole battery pack is 1500 Ibs. At no time have I (again) ever heard of the "last one" not getting enough charge. If your system is not correctly installed or maintained it can have problems, but a properly set-up system will not have these problems.
pjwest03
37
Vestal/NY
Rusty,
I dont't want to derail this thread but, I would like to hear (read) your thoughts on the Hybrid units sometime. I believe I work where the hybrid drive systems and battery modules are made that you're speaking of. I personally don't work in the power and drive shop though.
rustystud
2,796
Rusty,
There "Lithium-Ion" batteries in sealed 2volt cells. They are cooled by hydraulic oil coolers. The same buses are in service in Hawaii (they piggy-backed their bus order on ours) but they have AC units cooling them. The Alison transmissions are extremely expensive and we were the first transit agency in America to use them. The problem with the whole battery pack is their life expectancy of ten years max. At the time we first got them, a battery pack cost over $50,000.00 . Of course a Hybrid bus costs over 1 million dollars each. In my opinion a waste of tax payer money. "NeoPlan" had a bus that was based on a electric train engine design. A power plant ran a generator which ran electric motors to power the bus. It had the capability of using batteries also to go through the Seattle Tunnel . Instead they went with the "New Flyer" Hybrid bus. All that money spent on buses and training and special tools. I personally went through 320 hours of training and many others had over 600 hours of training. The few who went to the Alison transmission training school had another 3 months of training. Then there was the special technicians from Alison who worked with us for over a year. All payed with tax payer money. According to Federal Law, if a vehicle is bought with over 50% Federal Funds then it must be in service for a minimum of 15 years. The batteries will fail before that time of course, so add another $50,000.00 to the tax bill. That's not counting all the other systems that will fail and need repairing before that time is up. Now I don't know if this is true but one manager once told me the total cost of a bus over 15 years was in excess of 5 million dollars. We have over 1400 buses here in King County Seattle.
cattlerepairman
3,242
NORTH (Canada)
Our id**ts here can beat that! They also bought the "New Flyer" hybrids, then discovered that with maintenance costs and eventual pack replacement they made no sense, whatsoever. Their fuel savings were also much less than expected. so they converted them back to diesel only. However, the "Hybrid" stickers stayed on....as to not upset the "green" public!
rustystud
2,796
Yeah I forgot to mention the "fuel savings" these buses were suppose to have. Did you know all these buses need coolant heaters to keep the engines at operating temperatures ! The stupid Cat C-9 engines do not produce enough heat in a bus system with the hundreds of feet heater hoses for the passengers heating system. Including all those heater cores ( 8 on a average bus) . So these little heaters using diesel fuel are just pumping away to keep the bus warm. Even at idle. Plus the Cat C-9 is not that great or fuel efficient of an engine anyway. So the average Hybrid bus is getting 3 to 4 MPG ! It's a real winner of a combination !
