M35 in use questions
collector
Hello. I am British, living in USA.
I read something about the M35s, and perhaps other military equipment, can only be owned by Americans. Is this true ?
I could get around this by registering a truck to my US registered company, or to an American friend.
I always liked the M35s but never had a good excuse to buy one before now. I have a client that stores dies with me. This client needs a die just a few times a year, but likes to have them delivered, rather than come to collect. From January 2008, I will be responsible for this client. Some of the dies weigh up to 5 tons.
With the 5 ton axles, is the M35 a suitable vehicle to deliver / collect these heavy dies with ?
The client usually only requests use of one die at a time, so the weight limitation of one isn't a problem. The alternative is to simply buy a regular flatback truck, but I would like to give the M35 a look in if possible.
Any advice on this and the ownership question, much appreciated !
gimpyrobb
dumpsterlandingfromorbit!
27,791
787
Cincy Ohio
I'd just find one that is for sale by a private owner. If you move in southern In. there may be members available for help. Welcome to the site.
acetomatoco
9
As far as carrying the 5 ton dies, look at the specs for the truck... The carrying capacity cross country is 2 1/2 tons, but on the road is 5 tons...and overloading the gov't specs is routinely done. So long as you don't have too far to travel, such as 100s of miles, you should be fine. In the winter in IN you will need tire chains as the NDT and NDCC tires are terrible in slippery conditions. In my opinion, rental of a truck to move the dies on a few times a year basis will be more economical.
Blood_of_Tyrants
11
Lebanon, TN
If this is purely an economical decision, you would be better off renting a truck and hiring someone to deliver the die.
If this is an, "I want a deuce to play with when I'm not using it for business" decision, then by all means, get a deuce. Be prepared to do some work to them, after all, they ARE fairly old trucks.
