OldDominionIron
- 2
- 18
- Hampton, Virginia
I'm getting my deuce ready for painting. I'm using an angle grinder with either a knotted wire wheel to take off any rust, and a angled 36 grit sanding pad to remove excess paint down to either bare metal or primer. Since I'm not painting it immediately (I can only get a few hours here and there to work on the truck) I spray the areas as I do them with a rust-preventative primer (with zinc). I also plan on spraying on a coat of primer before going on with the final color. I have a local paint supplier (PPG) I plan on using, hoping they can match the original green that is still on the axles/differentials. The areas I'm doing feel pretty smooth when I finish, but I'm hoping the primer will even out any differences in surface height before painting. My question is should I go over the truck with a finer grit sandpaper (probably in a hand, random orbital sander) before spraying the truck, or just go ahead and primer/paint?
Dave
PS Pic is of my truck with the front bumper and right engine panel primed/painted to check out color/finish.
Dave
