m35 starting problem
mill1970
worcestershire uk england
can anyone help when my multifuel m35 is running she runs great but starting here is such a problem either when from cold or hot she is running on 60% petrol 40% diesel has anyone any ideas whot the problem might be
mill1970
m35 starting probs
yes the intake fuel feed is fine when you turn the pump on and loosen the bleed screws it pumps out finr i also took the pipe of the hydralic head and there was plenty of fuel pumping out
WillWagner
2,725
Monrovia, Ca.
There's your problem, too much gas in the mix. Put mure diesel in it and you should be good. Mine does the same thing if I put too much gasoline in it.
