M35 wheel cylinder
Rocco
Lynchburg VA
is it cheaper/ worth it to buy the rebuild kit for them
or just go ahead and buy some new ones.
what comes in the rebuild kit for the wheel cylinder just the 1 3/8 rubber piece's?
And how much are the rebuild kits?
WillWagner
2,728
Monrovia, Ca.
Guess it would depend on if the cylinder was pitted beyond reuse. I'd buy a couple of new ones and the same ammount of kits and build them as needed.
WillWagner
2,728
Monrovia, Ca.
I just did the wheel and master cyls on the 105. It's been forever since I did a rebuild on any brake part. If they are in good shape, do the rebuild. It's fun!
1,808
I'm a diehard fan of rebuilding them. If they are beyond economical repair, I'll replace. Even new cylinders I buy get torn down and inspected, never know how long they've been on the shelf. Kits run under $7 from a dealer and about $13 from NAPA. I buy my kits from www.odiron.com as they are fresh.
jasonjc
289
Gravette Ar.
The kit from OD Iron and Teds are Star brand. They come with a new spring 2 rubber cups and 2 new outter seal boots. I rebuild mine I've got an extar set so when I do a truck all I have to do is put them in. And then in free time I sand blast , hone , paint and replace the parts in the old one's. Then I have a set for the next truck.
WW2Chevy
Bloomington, IL
Just curious why this is in the WWI / WWII >> CCKW forum and not the "the Duece" ?? The price and availability of CCKW wheel cylinders is NOTHING like the apparent availablility of M35 cylinders :(
Fresno, Ca
Rebuild kits
Kenny,
Do the ones that you buy from NAPA have the pistons?
The ones that I found only came with the cups and caps on the ends. I found that by going to a good truck brake shop you can buy a box of the cups a lot cheaper.
If the pistons are scored, it is usally from rust and then there are usually pits and I trash them. I found that even if you hone the pits that it will still rust there. You can try it by letting the cylinder sit out for a few days and see if the rust will return.
John
1,808
RE: Rebuild kits
John, I can't afford ther NAPA ones. I used to buy them from Teds Trucks and now ODI.
