M35A1 HELP w/reg #'s?? badge plates empty
irontoys
Chesapeake/VA
Hello,
I have a M35A1 I picked up from a GL auction. Badge plates are not filled in. Rather than scour the complete chassis in search of a number, I figured I would ask the experts where to look precisely. I guess it would be stamped on the frame somewhere? Any helpful hints appreciated.
hole
Alta Loma , Ca.
Start with the left front frame rail above the diff, If it's old enough it might be on the right side in same location. FWIW, I've yet to find the #'s stamped in my frame, the only way mine was ID'ed was by using the USA/ Hood #. Look for Carnac's 2009 truck ID thread for help.
GoHot229
I found mine on the rear area pictured. A word of caution though, only use a wire brush on a side grinder, and not a sander or you may loose the numbers all togather, sometimes their not stamped any too deep into the metal of the frame
