M35A2 Alternator/Generator Needed
SierraHotel
Haymarket, Virginia
The back bracket on my alternator used to be cracked. After a test run yesterday, the front and rear brackets are both history.
Obviously I am now in need of a new…actually good used…alternator. Anyone got any extras they wish to part with inexpensively?
FormerNewMVGuy
10
stockton NJ
kublos surplus has them for $225 + shipping, I belive they are military rebuild's .
I have one that the bracket was cracked and then broke, I fixed it with JB Weld , Still holding! I have one that has a bad armature but the case is good.
beaubeau
Salisbury,N.H. 03268
If you know any rebuilders, have them modified and do up anDelco remy to replace yours. It cost me 125.00 for new-rebuilt. You can modify Alt. brackets to accept the Delco. I also had one done up for my 24 volt Excavator, and was simple to chance. Good luck, Phil
m16ty
211
Dickson,TN
Re: RE: M35A2 Alternator/Generator Needed
Yes, if you don't mind keeping it original a standard Delco Alt. can be made to work on 24 volts.
