commandojd
- 1
- 8
- Deshler OH
I recently purchased a Deuce and a half truck and the 2 mill spec 24volt batteries decided to take a dump...... What type of batteries could I replace the old ones with?????
thanks
thanks
EACH battery is 12V conected so you get 24VI recently purchased a Deuce and a half truck and the 2 mill spec 24volt batteries decided to take a dump...... What type of batteries could I replace the old ones with?????
thanks
If the Optima batteries will fit in the battery box, cable connections are OK, and they have enough CCA, they will work. Optima batteries come in different models. Orbitals are smaller dimension than 6TLs so you would need to secure them.I use Optima batteries for everything around here, will they work good for a deuce too? Im asking cause I have 6 laying around not being used anymore.
We currently have 3 A3s, and 2 A2, all of which have Interstate group 31s in them. Flip the screws on the pull out/lock down handles so the threads face out and its a nice snug fit in the plastic battery trays. My .02 Can't beat factory seconds from Interstate for $45 each.I just got some group 27 from Walmart for my A3. The group 31 would not fit in the plastic battery box, To long. The group 31's will fit in the metal battery box.
Get as many CCA as you can find.
Find the local wholesale distributor in your area for Interstate. Request factory 2nds, not refurbs. There is a difference in my opinion, and guy who works at our local distributor confirmed this.Where can you find the factory seconds..........? Do you have a link..?
