M35A2 Brake issues
kenny45
Bartlesville/Oklahoma
First off hello, I am new so please forgive me if I am posting this in the wrong area. I recently bought a M35A2, I drove it home with no problems. Once at home I checked the brake fluid and it was fine, and then a few days later I had little to no brakes. I checked the fluid again and then bled the brakes, thus leaving me with no brakes. I haven't seen any leaking from the back side of the tires, decided to take the front hubs off to inspect the wheel cylinders, both wheel cylinders were fine and the brake pads were non-existent, and my wheel bearings were in bad/need of replacement as well. I replaced all wheel bearings and brake pads on the front axle, bled the brakes again and the peddle still goes straight to the floor. I checked the boot around the master cylinder, it wasn't leaking. I have little knowledge on these types of vehicles and am learning as I go, but I am at a loss of what to do now. I have read quite a few of the TM's. Since everyone else on this page probably has a way better understanding of these vehicles than I do, I was wondering if anyone else has had this problem or could give me some troubleshooting tips on where to start for my description. Any and all ideas and help would be very appreciated. Thanks again in advance.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
It is a single circuit brake system.
If the front was bad, I bet the rears are too. Time to dig in to them also.
The reason I first mention SINGLE CIRCUIT is because if ONE part on the brakes fail, they all fail!
Once you go through all the brakes, you bleed the air-pack first, then the rear axle(right & left), then the middle axle(right & left), then the front(right & left).
This thread should help:
http://www.steelsoldiers.com/showthread.php?121471-M35A2-Brake-Issues
sigo
Lieutenant Colonel
392
Leavenworth, KS
Are you bleeding the air pack as well? Any leaks at the air pack?
edited to add, I should have read gimps post first.... He covered it.
