Lieutenant Dan
- 6
- 18
- Reading Pa
Ok so I got my rear all back together today re packed bearings and the whole 9.... brake shoes are like brand new or all but......
So I followed the tm on major and minor brake adjustment. The right side went beautiful with .010" on the bottom and .020" on top. Backed off till no drag.
Now the right side was a different story. The bottom adjusters seem to push the shoe up and makes it tight at the top not the bottom on both shoes. I tried clockwise and counter clockwise tighten the top first then the bottom and tried them evenly. The best I could do was .035 " at the bottom which puts the top at almost completely bottomed out with zero adjustment meaning they are completely loose. I got it set nicely with no drag but I don't like the bottom gap cause its going to wear the shoes funny. I can't see why this is doing this. The anchor pins where fine and I put the punch mark showing the high spot towards each other so they would adjust correctly.
Any help on this? I'm probably going to have to pull it all back apart again just because I can't figure out why it's doing this. It just sucks since I got it all fresh grease and cleaned and rtv and corked the key ways. Man it makes me furious.
